2014 TPMS Light
Old Sep 27, 2020 | 02:21 PM
Druizer's Avatar
Default 2014 TPMS Light
I got a code from the OBD2 the was C2126. I can read my sensor id via the car OEM but I can't activate them. All 4 tires are showing a red X. Any ideas?
Old Sep 28, 2020 | 04:09 PM
Did you register the sensor ID's into the ECU?
Old Sep 29, 2020 | 02:38 PM
Druizer's Avatar
it is the original sensors. I tried to scan them with my Autel TPMS TS601 scanner. Every tire shows a red x. When I run the diagnostic it gives me the code C2126. I can erase the code but it comes back. I'm thinking the control module. Any advice would be great. Also where is the module located? Google is no help.
Old Sep 29, 2020 | 09:58 PM
Control module, receiver, sensors not registered, bad sensors, bad wiring.
Try resetting the system. See video below:
https://www.google.com/search?rlz=1C...4dUDCAw&uact=5
Old Oct 1, 2020 | 04:34 PM
Druizer's Avatar
Thanks! For the life of me I can't find the TMPS button. Not in the glove box, under the glove box, or to the left or right of the steering wheel down low.
carolinatim
Aug 20, 2021 09:47 PM
Camry Prime
Sep 28, 2016 03:56 PM
DURABLEOILCOM
Jan 22, 2013 05:51 PM
bruce334
Mar 11, 2009 11:04 PM
SB Ridge
Oct 10, 2008 03:24 PM
