93 Camry sunroof/dome light quit
Old 05-06-2018, 12:16 PM
odaveplz's Avatar
Unhappy 93 Camry sunroof/dome light quit
1993 Camry sunroof switches and dome light in sunroof accessory panel stopped working. My mechanic says it is the sunroof motor but I do not think he is right. I believe it is a fuse or a relay.. Does anyone have an idea where the fuse/relays are for the sunroof? Also (possibly ) related . At the same time the power antenna ceased to work. Not sure if these all relate or I have separate issues. The fuses shown in the owners manual seem ok. there is no diagram for the relays
It seems like a power related issue and not mechanical
Old 05-06-2018, 03:12 PM
Have you checked the Dome fuse? Location is engine compartment, drivers side.
The power antenna fuses are Dome, ECU-IG and CiG/Radio. The other two fuses are located in a panel, lcation drivers side of dash behind dash ash tray.
Old 05-06-2018, 03:35 PM
odaveplz's Avatar
Thank you for responding.You say there are fuses behind the ash tray or do you mean the change holder? I never noticed fuses behind the ash tray.
Old 05-06-2018, 03:57 PM
Change holder = ash tray. Carefully remove holder draw and look behind it for fuse a box.
Far left side of lower dash.
felixtibs
02-27-2020 12:57 PM
numbersguy
10-24-2010 04:33 PM
floridarider
10-11-2010 10:37 PM
floridarider
10-10-2010 10:01 PM
ll5175
05-21-2008 08:37 PM
Quick Reply: 93 Camry sunroof/dome light quit
