1991 toyota camry dome light question
Old Oct 24, 2009 | 04:50 PM
felixtibs's Avatar
Default 1991 toyota camry dome light question
My gf just got a 91 camry: dome light not working.
-replaced bulb
-checked dome fuse in engine compartment
still doesnt work...am I missing something?
Whats next?
Old Oct 25, 2009 | 04:14 PM
ddrink's Avatar
I have the same issue with my 91, dome light won't come on when door is opened, but can be turned on at the switch. I haven't taken the time to look at it, dome light didn't work in my last truck, so I'm kinda used to it. If you figure it out let me know. If I every look into mine I'll post back.
Dan
Old Oct 27, 2009 | 09:40 AM
elhobo's Avatar
hi, it could be the door sensors. they're simple but they can get stuck. That's what happened to my 92 Camry. It's a relatively easy DIY.
Old Oct 28, 2009 | 02:39 PM
felixtibs's Avatar
great, that could be it.
Would you mine telling me where to wlook and how to do it?
Old Oct 29, 2009 | 09:31 AM
elhobo's Avatar
yes sir! it's in the door jams. It's a round piece of rubber that get's compressed when u close the door. Click on that DIY, there are no pictures but if you'd like i will post pics of me doing it since one of my door sensors are stuck anyway.
http://www.toyotanation.com/forum/sh...d.php?t=195956
Old Feb 22, 2020 | 08:59 PM
jvenderley's Avatar
My dome light works when the door is open but not in the "on" position. Any ideas on how to fix? 1991 Camry...
Old Feb 23, 2020 | 12:14 PM
The bulb always has 12 volts going to it, The dome switch determines if the bulb is grounded (to complete circuit) to chassis (always on) or goes through a door switch. Check dome switch to make sure the bulb is being grounded when dome light set to on.
Old Feb 23, 2020 | 12:32 PM
jvenderley's Avatar
It does appear to be grounded. I think you are on to something, as when I went out with a screwdriver to make sure the connection is Beijing made, the light did come on. I am guessing that is what the issue is. I will continue to fiddle with it and maybe it will have a better connection. Thanks for the explanation...
Last edited by jvenderley; Feb 23, 2020 at 12:40 PM. Reason: Took advise and checked it out again...
Old Feb 27, 2020 | 12:57 PM
jvenderley's Avatar
Default Fixed
It appeared to be an issue with the ground wire. Bent the connection a bit and it worked. Thanks!!!
pirate694
Feb 5, 2011 07:57 PM
numbersguy
Oct 24, 2010 04:33 PM
floridarider
Oct 10, 2010 10:01 PM
woundedknee
Aug 20, 2010 10:11 PM
lawless
Sep 26, 2006 02:02 PM
