96 camry lost electrical
Old Jun 22, 2015 | 07:01 PM
Maxwell Sparks's Avatar
Default 96 camry lost electrical
My camry when I turn the key to the on position. It only shows the airbag indicator light and will not start. I checked several of the fuses and there isn't any power getting there. At a loss. Battery is good but no continuity at fuse box . Please help.
Old Jun 22, 2015 | 10:46 PM
No continuity at which fuse box?
Does anything work in the car if the ign switch is turned to on?
Do the head, tail and stop lights work?
Old Jun 24, 2015 | 11:26 AM
sorry had family emergency, there is no power, no lights interior or exterior. took the battery to have it tested was good replaced negative cables cleaned ground and replaced terminals. still no power. as i said earlier with key in on position i only see the airbag indicator light.
Last edited by Maxwell Sparks; Jun 24, 2015 at 11:29 AM. Reason: additional info needed
Old Jun 25, 2015 | 11:06 AM
If no external lights work such as head, tail and stop lights, check the 100A Alt fuse. Location is engine compartment, in a fuse/relay box next to the drivers side fender.
Praween
Sep 11, 2011 10:09 PM
hkaufman
Jul 11, 2010 10:16 AM
sontakke
Sep 4, 2007 05:27 AM
twinpack
Jun 9, 2007 06:52 AM
JBCAMRY07
May 29, 2006 01:35 AM
