96 camry window and door lock issue
Old Jan 29, 2011 | 05:55 PM
eripike's Avatar
Default 96 camry window and door lock issue
hey there i have a 96 camry 4 door
recently we have had an issue
with window and door locks
none of them work?
we thoughtt that maybe the master switch on the drivers door was bad so we tried that with no luck so no windows or power locks
any ideas or something we can try i might be missing?
maybe a relay somewhere for them i dont know about
thanks
Old Jan 29, 2011 | 07:11 PM
Do any of the passenger door window or lock switches work?
Old Jan 30, 2011 | 02:18 AM
eripike's Avatar
Nope nothing works
Old Jan 30, 2011 | 01:51 PM
If the power windows work and gauges, power is getting to the power relay and gauge fuse that supply power to the door locks.
Depending on the year of car there may be a DOOR fuse located in a fuse box behind the drivers side kick panel. If no fuse or fuse OK and everything above works could be a broken wire.
The wires running between the drivers door and chassis can break due to flexing. You will need to remove the door panel to access the door lock console.
ducati4882
Dec 9, 2024 09:18 AM
csanders
Jan 8, 2011 10:28 PM
Camryguy2009
Apr 8, 2010 11:28 AM
mx3man83
Jul 4, 2009 11:24 PM
subpar1957
Aug 21, 2008 08:49 PM
