no temp gauge
Old Nov 23, 2011 | 12:53 AM
tyrantfour's Avatar
Default no temp gauge
hey guys, i replaced my bmc and now my temp gauge isnt working. i think i broke a wire or missed a ground somewhere. the gauge worked just fine before hand. looking around i cant seem to find anything unpluged. all fuses are good. i was hoping to find a wiring diagram but havent been successful.
Old Nov 23, 2011 | 09:39 AM
bmc ?
Old Nov 23, 2011 | 05:29 PM
tyrantfour's Avatar
brake master cylinder
Old Nov 23, 2011 | 08:47 PM
Year of car, V6 or 4 cylinder?
Old Nov 23, 2011 | 10:19 PM
tyrantfour's Avatar
sorry i updated my signature after this post with all the info but it dosent seem to work in retrospect....
its an 87 3sfe automatic
Old Nov 24, 2011 | 09:52 AM
The water temp switch is located under the coolant bypass housing above the starter.
Check if the harness plug was disconnected.
Water temp wires are yellow/green stripe.
If the other gauges work, the fuse is OK.
Old Nov 24, 2011 | 02:56 PM
tyrantfour's Avatar
beautiful information...i found it just as you said. it was connected but i pulled it and there was a good bit of corrosion. sanded the contacts a bit and now the gauge is working! the rest of the switch is just as green and will likely get replaced. strange tho, it worked just fine before i did the bmc but after refused to work from corrosion. never would have guessed that.
thanks for the help!
Old Nov 24, 2011 | 08:09 PM
Great job! Thanks for posting back with the fix.
Old Nov 26, 2011 | 03:33 PM
tyrantfour's Avatar
EEEEEEERRRRRRRRRRR its so irritating searching forums to find someone with the exact problem i have, years old, and no outcomes. In a perfect world...lol
Old Nov 26, 2011 | 03:40 PM
Concur!
100's of problems are resolved but no one posts back with the found fix.
95toycamle
Aug 18, 2009 07:43 PM
sammo
Aug 8, 2008 07:19 PM
vin888
Mar 6, 2008 08:39 PM
saxman
Oct 3, 2007 11:06 PM
tg305
Nov 5, 2006 01:24 PM
