push button start
Old Jan 15, 2018 | 10:54 AM
Gail Brown's Avatar
Default push button start
2012 hybird camry has push button start
will not start on cold mornings does it need to warm up
or is there something we can do?
Old Jan 15, 2018 | 11:56 AM
Nothing happens when you push the button?
Or when the button is pushed the engine turns over but doesn't start? Or the engine turns over but slowly?
Old Jan 15, 2018 | 12:16 PM
Gail Brown's Avatar
the dash lights come on just will not crank have to sit and wait about 10 to 15 min. before it will start
Old Jan 15, 2018 | 03:10 PM
Check the owners manual for the proper engine start procedure.
This being for the brake to be pressed, trans in Park, etc. Then once done a ready light should change from say yellow to green. This indicating it is OK to press the start button and expect the engine to turn over.
If the light is green indicating all is ready for engine start. But nothing happens when the start button is pushed. The issue could be a failing auxiliary battery (see owners manual). Batteries have less output as the air temps (and thus battery) get colder.
Or corroded battery connections.
If in following the start procedure you can't get the light to turn green. Something is wrong such as bad brake light switch, etc. If the light is not green, the engine will not turn over when start button is pushed.
Old Jan 15, 2018 | 09:59 PM
Gail Brown's Avatar
Thank you for your help had the battery checked & replaced the battery,daughter is happy again.
Old Jan 16, 2018 | 12:08 PM
Great job! Thanks for posting back with the fix.
BS10OH
May 3, 2013 01:31 PM
js_willi4848
Apr 8, 2013 12:52 PM
automaticj5
Jan 6, 2012 08:05 PM
ferrarifan
Jan 2, 2012 03:13 PM
ivaylonikolov
Mar 24, 2011 03:46 PM
