REAR LIGHTS WARNING
Old Aug 18, 2008 | 03:53 PM
TMART546's Avatar
Default REAR LIGHTS WARNING
87 LE SHOWS REAR LIGHTS WARNING EVEN THOUGH ALL LIGHTS WORK-POSSIBLE CAUSES?
Old Aug 18, 2008 | 07:22 PM
Default RE: REAR LIGHTS WARNING
You checked both tail and brake lights?
You might change all the bulbs and clean the socket terminals. Increased electrcial resistance caused by a failing bulb, corroded socket or bad wiring can cause the indicator light to go on.
The sensor unit itself can fail causing this problem. It's location is the trunk, drivers side behind the lining.
Old Sep 5, 2008 | 02:52 AM
freude09's Avatar
clean or change the bulbs and the socket terminals, and the sensor unit could be causing the problem in your car...
Old Sep 5, 2008 | 01:52 PM
94camguy's Avatar
Do I see an echo?Thanks for the bit of info I've been having the same issue lately. I think mine is wiring, I also have my reverse lights not always engaging.
mjam714
May 31, 2012 08:57 PM
Suny
May 20, 2012 12:16 AM
jetfire
Jul 3, 2009 02:34 AM
chris
Aug 11, 2008 05:07 PM
ch1ckaloni
Aug 30, 2006 05:10 PM
