reversing light
Old Apr 21, 2009 | 12:08 AM
barney33's Avatar
Default reversing light
bulb ok but lamp does not light up is it on a fuse
Old Apr 21, 2009 | 12:59 PM
Year of car?
The wiring harness in the trunk spilts off to the trunk lid and then reverse lights. This area can be damaged due to trunk usages, check for broken wires.
Old Apr 22, 2009 | 02:11 PM
barney33's Avatar
wiring ok still no light , its a 1997 model any clues
Old Apr 22, 2009 | 08:59 PM
Power comes from the Gauge fuse.
Check if power is getting to the lamp sockets, the wiring ground point and switches.
If a manual trans there is a backup light switch on the trans.
If auto, the system uses the Park/Neutral switch.
Old Apr 23, 2009 | 11:30 PM
barney33's Avatar
Default reversing
power seems to be flowing,is the switch under the gear lever cover in the car or outside underneath the car directly under the gear lever. cheers
Kayla
Apr 16, 2012 10:40 PM
bassposse
Jul 30, 2009 09:52 PM
bobo45
Jul 17, 2008 10:42 PM
Blue07CamNY
Nov 4, 2007 06:13 PM
