2000 Toyota Camry - Evap Code Issues
Cold or hot does not matter. Engine should be at idle. If the engine stumbles when vacuum is applied, the EGR system is working.
Get a mechanics mirror (small mirror at the end of an adjustable stick) and look behind engine for VSV's (vacuum on/off solenoid) Determine if the smoke is exiting the valve(s).
May look like the item in the link below:
https://www.rockauto.com/en/moreinfo...g%2F1vhTgfM%3D
