2002 Camry xle 2AZFE engine clatter??
Old Jun 11, 2020 | 10:59 AM
Jbar2016's Avatar
Default 2002 Camry xle 2AZFE engine clatter??
I am trying to figure out an engine noise and whether or not it is a serious issue or not.
i recently bought this car, it has 196k miles. The symptoms i get happen mainly when cold, and sound like valve clatter to me. It happens at first start for 1-2 seconds and is sometimes better or worse, after its warm the engine is super quiet and usually doesnt clatter again until its been sitting 2 or more hours, and then its "usually" not as loud as first start.
i changed the oil right after i got the car, i used full synthetic napa 5w30 and a napa silver oil filter. Then i pulled the p.s. pump and cleaned the oil control valve filter which was in need of cleaning, testing the valve itself determined it needed to be replaced, with a clean filter and a new ocv solenoid it is still making that noise
I am hoping somebody can help me out, here is a video of the noise i get, it does get louder and more pronounced at times then the video shows.
https://youtu.be/aTRI7THpLMc
Old Jun 11, 2020 | 03:06 PM
The engine is known for cold start chatter.
Use a section of hose as a stethoscope to narrow down the location of the noise. Check in the areas of: intake manifold, intake camshaft timing gear, valve cover area, firewall side of timing chain cover.
Old Jun 12, 2020 | 05:22 AM
Jbar2016's Avatar
Thank you for letting me know the places to check, i have an automotive stethoscope so i will use it to track down the noise location and let you know what i find, may take a while as it only lasts a second or so, but i will update as soon as i find something
DM11
May 21, 2020 01:06 PM
Pirate Labs
Apr 14, 2019 02:05 PM
Bassman1955
Dec 5, 2017 12:42 PM
chrisv
Mar 9, 2015 12:41 PM
88_os
Apr 6, 2009 05:55 AM
