Engine Noise
Old May 20, 2020 | 12:01 PM
DM11's Avatar
Default Engine Noise
I have a 2011 xle V6 that has 24,500 miles on it. Recently, the camshaft oil control valve in bank 1 went bad. I decided to change all of the camshaft oil control valves in bank 1 and 2. At the same time, I changed the spark plugs, oil and filter.
The engine has a truck like sound, not quite as it once was. There are no codes, the engine idles at the right speed with no fluctuation, and it accelerates normally. I have used fuel system cleaners to keep the injectors etc. clean.
I have tried using an automotive stethoscope to try and isolate where the sound is coming from.
I can’t find any singular origin.
Does anyone have any ideas about this?
Old May 20, 2020 | 08:51 PM
Different weight of oil, filter issues?
Listen at the camshaft pulleys. The VVTi mechanism could be rattling.
Old May 20, 2020 | 10:50 PM
DM11's Avatar
The manual calls for 5w30 which is the oil weight I have been using. I also have been using Wix XP oil filters. I could try a different brand of filter to see if it makes a difference. I’ll also listen at the camshaft pulleys to see if the VVTi mechanism is rattling.
Thank you toyomoho for your ideas to solve the problem. I appreciate it.
Old May 21, 2020 | 01:06 PM
Wix filters are excellent.
chiefmetamorph
Dec 10, 2017 11:46 PM
75gl1000
Jan 2, 2016 09:32 PM
KC413
Apr 4, 2014 09:42 PM
LenoCeballos
Aug 3, 2013 05:34 PM
leon_nerd
Jan 13, 2013 06:18 PM
