'92 Camry transmission issue - low gears
Old Jun 16, 2012 | 03:05 PM
Adam Nesbitt's Avatar
Default '92 Camry transmission issue - low gears
I have a 1992 4 cylinder 2.2L automatic Camry. The car starts with no issue. When i shift into Drive it shifts rather hard. When the car shifts into second it is also a little hard. Every gear after that shifts smoothly. The car shifts into reverse fairly smooth as well.
I have recently replaced the trans. filter and added new fluid along with some Lucas trans. treatment. I am still having this problem.
The confusing part to this story is that after i have been driving for a few minutes the car shifts fine through the lower gears. Now what could possibly be causing this? Any suggestions and/or tips are welcomed.
Also, this is my first post
Old Jun 17, 2012 | 12:01 PM
What condition was the drained fluid in, black, thick, etc?
If the fluid was not in good condition you might replace it all. If the pan is drained. 2/3 of the fluid is still in the torque converter.
Also check engine mounts.
Old Jun 29, 2012 | 05:33 AM
Default fluid
The fluid was not in horrible shape. It was darker than new fluid but it did not smell burnt. Is the torque convertor something i could deal with myself? I'm going to look it up in my Haynes after work.
Also, i will check out the engine mounts
Old Jul 11, 2012 | 06:20 PM
Still no luck
Old Jul 11, 2012 | 08:32 PM
boricua's Avatar
problem cause by worn internal seal .after trans worms up the seals expand to the normal shape and the fluid pressures goes back to normal , a worn seal when cold won't seal like it should ,this will cause hard shifting , some times a trans fluid conditioner will fix problem temporarily , i suggest save some $$ for a re-manufacture trans .
pimppy
Jul 12, 2011 10:12 AM
trunksbomb
Jun 1, 2011 08:06 PM
koolnerd711
Dec 2, 2010 11:49 AM
hepsi
Jan 24, 2010 08:14 PM
