94 LE power steering failure...Need advice/help
Old Oct 10, 2009 | 12:50 PM
Riggs.45's Avatar
Default 94 LE power steering failure...Need advice/help
i was driving yesterday and my power steering failed as i was getting off the off ramp, i turned into a parking lot and tried to put it in a parking spot but when i pressed down on the gas nothing happened. i turned the car off, and now it wont start up again, the engine is turning over but it wont fully start. All my electronics work so i don't think its the alternator. i have a hunch its some kind of belt (timing maybe?) my serpentine is fine, and all my fluids are good. any suggestions? if possible i would like to fix it myself.
Old Oct 11, 2009 | 12:07 PM
Joel_CA's Avatar
It sure sounds like your timing belt either broke or skipped a few teeth to the point where the engine will no longer start.
JJ
Old Oct 27, 2009 | 09:53 AM
elhobo's Avatar
crazy guess, but maybe the brake booster cable came off. that causes the car to stall.
rikkyjay
Aug 13, 2015 08:46 PM
Lovehatetony
Oct 21, 2011 10:05 AM
wil
Jun 14, 2010 01:26 PM
not a mechanic
Apr 18, 2010 07:23 AM
Mean Linguin
Nov 13, 2008 05:42 PM
