99 Camry LE transmission problem
Old Sep 10, 2009 | 02:56 PM
johnwuy's Avatar
Default 99 Camry LE transmission problem
My car is a 99 Camry LE. I sent it in to get a transmission fluid flush, and now they say there's a problem with the transmission in that it doesn't shift gears correctly. The fluid they use was the proper ATF, and now it needs to be sent to a transmission shop to be taken apart and fixed.
I'm just wondering, if I'm getting screwed. When I brought the car in, there was nothing indicating a transmission problem. There was some weird sound with the brake, and that was it. I've heard that after a flush all the build-up might get dissipated and clog the pumps whatever, but how would it make gears not shifting right?
So I'm just wondering if it's even possible to have a transmission problem with a Japanese car only after 10 years. My biggest concern is that before sending it in, there was no signs indicating a problem. The mileage on the car is 105,000
VanNguyen
Feb 2, 2018 02:31 PM
bossofdakross
Sep 21, 2013 07:12 PM
stubirdnb
Nov 21, 2008 01:17 PM
paulgoh
Jul 23, 2007 08:28 PM
Black00GTS
Nov 16, 2006 01:36 AM
