99 Camry shifter stiff
Old May 17, 2008 | 04:56 AM
jackman's Avatar
Default 99 Camry shifter stiff
Bought 99 Camry, 71k,and automatic floor shifter is much stiffer than my 00,
whick is very slick feeling.
Trans fluid is dark, but not burned looking
Anybody else have this problem/ solution?
00 stuck a little after daughter spilled iced tea over it, but after taking cover off, I was able to clean it up pretty good.
Old May 17, 2008 | 11:44 AM
Default RE: 99 Camry shifter stiff
There are several areas to check. The shift console itself, a push/pull cable running from the trans shift lever to the console, either could be binding. The shift mechanisum inside the trans has a detent system to stop the lever in each gear position.
You can disconnect the cable from the trans shift lever then move the shift in the car to check if the problem is in cable/console or trans.
If original trans fluid suggest changing it. This is about the right mileage, changing all the trans fluid now will GREATLY increase its life.
haze
34
Feb 24, 2020 04:09 PM
retiredat44
Aug 30, 2017 10:27 PM
kwash703
Jul 18, 2014 01:27 AM
blkxlecamry
Feb 13, 2011 12:45 PM
zahmed
Dec 22, 2008 01:41 PM
