Advice/Help on trans cooler 1993 V6
Hi,
I'm going to install a transmission cooler on my 1993 Camry V6 in prep for towing a 2000 lb. trailer.
Any advice would be appreciated. Can you help me in identifying the two hoses coming from the trans...one is the supply and one is the return. Which is which?
I plan on installing the cooler "in line" with the radiator cooler....is that the best way?
Does it matter which way the fluid flows?
Can you suggest a brand/model cooler that will install easily?
Can you direct me to a site with pictures of this job?
I know this is a lot to ask...especially since I am a new member here. Thanks so much for the help.
Chuck
Chuck
Gen3Guru93
Jan 30, 2015 08:47 PM
