can i cam swap
Old Mar 24, 2008 | 08:48 PM
colbetzor44's Avatar
Default can i cam swap
i am doing a head gasket change on a 93 camry 4cyl and am wanting to know if i can take the cams out of my old engine and swap in the new engine
Old Mar 25, 2008 | 05:15 PM
Default RE: can i cam swap
Have done this on other engines. Don't think the cam bearing bores were sized for each cam.
Suggest checking bearing clearances if only by making sure the cam rotates freely when the caps are torqued down. You can also use a Plastigage, should be 0.0010-0.0024 with a max of 0.0039 inch. Of course recheck valve clearance.
carlos1787
May 23, 2009 05:57 AM
Seahunt
Jan 27, 2009 12:47 PM
yesnyes
Apr 19, 2008 12:26 PM
V6 5spdSTEF
Feb 3, 2006 03:28 PM
