Car will only accelerate in reverse Not Drive
Old Jan 26, 2019 | 08:57 AM
Steven Ayala's Avatar
Default Car will only accelerate in reverse Not Drive
Okay So Everything Started After One Morning I Was Driving My Mom To Work And Suddenly After Coming To A Stop I Pressed The Gas Pedal And Only Got A Loud Reving Noise. I Was Able To Get It To The Side If The Road. After Looking Closely I Could See I Had A Busted Hose Coming From The Tranny To The Radiator. So I Added Fluid Because The Car Was In A Tow Zone And Was Able To Move It 1 Block Away. Then After Getting The Vehicle Towed Home Replaced The Hose And Refilled With Tranny Fluid. Thinking My Problems Were Behind Me But When I Went To Drive The Vehicle It Would Not Accelerate in Drive. I Would Only Get A Loud Reving Noise. The Car Will Drive Fine In Reverse. Please Help Thank You
Old Jan 26, 2019 | 11:20 AM
Trans operation uses trans fluid which operates as a hydraulic fluid. The fluid also lubricate and cools the trans parts. If the trans runs low on fluid it will start to slip, become damaged from lack of lubrication, etc.
Check trans fluid level. This being at the full hot mark, trans fluid hot, engine on and in park. Check that the shifter lever arm is moving to reverse when the gear shifter is in reverse.
If all OK the lack of fluid may have damaged the trans reverse clutch due to overheating. This requires rebuilding the trans or replacement.
Silverstreak02
Nov 24, 2013 10:05 AM
umdaman
Aug 23, 2011 09:46 AM
camryjim
Mar 1, 2010 09:49 AM
cardman
Nov 17, 2008 10:56 PM
cisco2992
May 17, 2008 10:16 PM
