Engine cleaning
Old Aug 2, 2013 | 11:36 AM
Dcardsrule's Avatar
Default Engine cleaning
This may not be the right place to ask this question but, does anyone know of any special precautions to take when washing under the hood of a hybrid car? I don't want to get any thing wet that shouldn't be. Thanks.
Old Aug 2, 2013 | 02:07 PM
Might ask at the Toyotanation.com forum in the Camry Hybrid section for any info on areas to avoid.
Suggest if wanting to use a pressure washer to be extremely careful as it is not uncommon for the water to get into electrical connections resulting in the engine not starting or running rough. Troubleshooting the connections can be time consuming and difficult.
An engine having more electrical components such as a hybrid would be more prone to forced water intrusion problems.
If you do pressure wash avoid electrical system items, ign, computers, fuse and relay boxes, electrical connections, etc.
Would also extend this to oil and grease seals, protective boots, etc where the force of the water can push it past the sealed area.
Or use chemical cleaners or laundry detergent and a hose. A hose not under pressure from an attached nozzle should not allow forced water entry into places it should not be.
I pressure wash engines, generators, etc but am extremely careful where I point the nozzle plus avoid any seal, rubber boot, etc. as have found water can force its way into an area is should not be. If in doubt I wash by hand using chemicals or laundry detergent (which does not have solvents), or just wipe the area down with paper towels.
Old Aug 2, 2013 | 03:18 PM
Dcardsrule's Avatar
I'm just planning on using hose pressure no pressure washer.
Old Aug 3, 2013 | 12:19 PM
Should be fine then. Suggest after cleaning to keep hood open or start engine to aid in drying the engine.
tainted
Sep 27, 2012 09:18 PM
beunos24
Jul 28, 2008 11:21 AM
Autogeek
Mar 20, 2007 09:43 PM
Cephalgia
Apr 22, 2006 07:46 PM
marc780
Apr 10, 2006 06:22 PM
