Idle shut off problems
Old Dec 23, 2008 | 04:33 AM
adude247's Avatar
Default Idle shut off problems
I have a 2003 Camry 2.4L 2AZ-FE, with 150k miles. A few weeks ago I unhooked the battery to clean the terminals, when I reconnected the battery I cranked my car, which was cold by now, and it started up fine, but once it started to warm up, it began to idle low and then shut off. I turned my car off and restarted it, only to have it shut off again. The only way to keep it cranked is to rev the engine a little bit. I have no problems with it while it is driving, or when it is idling cold, but once the engine warms up it shuts off. Any thoughts!!
Old Dec 23, 2008 | 09:14 AM
Default RE: Idle shut off problems
This is a common problem with these models.
Suggest for now you just keep driving, the problem typically works it self out on its own.
The computer seems to have an issue with battery being disconnected and needs to readjust.
Old Jan 24, 2009 | 03:33 PM
05cam's Avatar
yea very common problem...ive had this happend to me a couple times so far. i recommend resetting it and then driving on the interstate for an hr or 2...this has seemed to help and keep the car from stalling in my case....
aahmes57
Nov 3, 2012 07:30 PM
Camry84
Nov 16, 2011 07:33 AM
Specvern
May 17, 2011 08:58 AM
mrancou1
Sep 11, 2009 08:39 PM
hoopz111
May 7, 2009 05:52 PM
