jerking while accelerating
Old Feb 29, 2008 | 09:31 PM
dusty01's Avatar
Default jerking while accelerating
hey, i recently bought a 92 camry with a 2.2 4cyl, and when i slow down under 10 mph without stopping and take off its jerks really bad, and also when i go from park into drive its like a 3-5 sec delay before it kicks into gear, any ideas whats wrong???? THANKS
Old Mar 1, 2008 | 12:24 PM
Default RE: jerking while accelerating
Try completely changing the trans fluid. If doing a drain and refill this could take 3-4 times as only about 2.4 qrts is drained at a time, the rest is in the torque converter. Drive a few miles between changes to mix the oil.
If not a dirty fluid issue the delay and jerking are signs of internal problems such as a clutch brake or worn torque converter clutch. These would require major repairs.
Old Apr 5, 2008 | 11:54 AM
escrosteve@yahoo.com's Avatar
If youre jerking that hard, you might just want to pull over..
Old Apr 22, 2008 | 07:14 PM
khooper's Avatar
You may have one or more wiring connections that are bad. When the engine is running well, try carefully moving the wiring harnesses under the hood back and forth, particularly those in the taped bundles that run between the engine and the body. Also check ground connections, especially those between the engine and body.
[align=center]_____________________________
Isuzu Rodeo EGR Valve in
Autopartswarehouse is great!
[/align]
leon_nerd
Jan 13, 2013 06:18 PM
Yobearcat
Mar 28, 2010 02:59 AM
aolsen
Nov 14, 2008 06:08 AM
stealthmode8384
May 29, 2007 05:38 AM
