Please help me
Old Dec 8, 2008 | 08:07 PM
vincent's Avatar
Default Please help me
My car is 2001 Camry , 4 cylinder 2.2 engine , it's about 122.560 km .
It is hard to start when the engine is hot . It usually take 2 cycles ( or turns ) to start the engine when it 's cold .
If it is hot , it takes longer to start the engine , the engine will turn 6 or 7 turns to start .
I tried to replace : spark plugs ,air filter , fuel filter , coolant temperature sensor , timing belt . I had injectors cleaned by dealer . But it didn't work .
Please help me . Thanks .
Old Dec 8, 2008 | 08:47 PM
Default RE: Please help me
Might be the Idle Air Control valve (IAC) or fuel pressure regulator.
Old Dec 8, 2008 | 10:28 PM
vincent's Avatar
Please tell me where the Idle Air Control valve (IAC) and fuel pressure regulator are . Thanks .
Old Dec 9, 2008 | 11:30 AM
IAC valve is under the throttle body. Suggest a Google search on cleaning the "IAC valve 5S-FE" which should result in many hits. A solvent cleaner is sprayed into the IAC air intake port. Use a throttle body cleaner that is plastic safe (do not use brake cleaner).
The fuel pressure regulator is at the end of the fuel rail having the injectors (passengers side). If the engine has one it will look like a small can (Toyota want on to move the requlator to the gas tank under the fuel pump).
The website www.autozone.com should have info on the above items in their Vehicle Repair Guide Section.
Old Dec 10, 2008 | 01:06 PM
vincent's Avatar
thanks Toyomoho . Merry Christmas and happy new year .
Old Dec 15, 2008 | 12:13 PM
vincent's Avatar
Hello Toyomoho ,
Would you please tell me to remove rear seat of 2001 Camry . I want reach to fuel pump . I don't see any bolt of the seat . Thanks .
Old Dec 15, 2008 | 04:35 PM
Merry X-mas to you and your family.
The lower seat pulls up from the front. It has a couple of tabs that drop into slots in the chassis.
Pull up on each side on each side of the seat by gripping under the front edge. Once released pull the seat out forward.
Old Dec 16, 2008 | 11:18 AM
vincent's Avatar
Hello, thank you very much for telling me to remove the rear seat. I see the cover of the fuel pump but no screw or bolt, look like it's glued to the chassis. Do i just pry it off and glue back after finish the job?
Old Dec 16, 2008 | 04:11 PM
Typically there are a couple of sheet metal screws holding the cover down. The cover is a thin steel plate covering a hole in the chassis, below which is the actual fuel tank.
Once the cover is removed you will have access to the top of the fuel tank and the fuel pump access cover.
mail2_jb
Nov 14, 2011 08:07 PM
ToyotaMan55
Jun 6, 2006 01:51 PM
Apexs20s
Apr 12, 2006 03:48 AM
duckypatos
Apr 4, 2006 08:39 PM
SeaKaye12
Nov 9, 2005 11:28 AM
