rough idle problem solved?
Old Mar 25, 2010 | 10:34 PM
brianjrealtor's Avatar
Default rough idle problem solved?
1993 camry 4cyl. with 250K miles
Had a rough idle problem and cleaned all sensors, new plugs, wires, etc.
still had a bit of a rough idle. I replaced the top motor mount "dogbone" and it helped. So, i thought what would happen if I took that mount out and try and start the car to see how it runs.
rough idle problem solved!
But, is this a good idea to leave that mount out permenantly??
Old Aug 7, 2010 | 08:37 AM
84runner's Avatar
Five months have gone by...
Update?
What sensors did you clean?
Do you still have the upper motor mount out?
Old Aug 7, 2010 | 09:12 AM
I've done alot to it..
replaced CTS sensor, O2 sensor, cleaned EGR valve and IAC valve...
cleaned injectors manually...
Old Aug 7, 2010 | 11:06 AM
Removing the mount solved the rough idle problem?
Some owners have "improved" the mount system by using a setup from a 1996. This has a much bigger rubber doughnut.
Old Aug 8, 2010 | 08:20 AM
84runner's Avatar
Are you still driving arount with no upper mount?
Old Jan 31, 2011 | 03:11 PM
johne610's Avatar
I sure wouldn't drive around without the top motor mount - engine will rotate fore/aft as you start/stop, and this is sure to cause other problems (broken wires, worn hoses, etc.) - not to mention extra wear/tear on the drive train.
rushmc
Apr 26, 2022 09:47 PM
kitronic
Jun 5, 2011 03:04 AM
pedro
Jul 27, 2007 07:06 AM
92V6Wagon
Jul 2, 2007 11:32 AM
green97le
Jun 8, 2006 12:32 AM
