seized engine?
Old Aug 6, 2008 | 09:03 AM
  #11
Default RE: seized engine?
A short block would work, an autoparts storeshould be able to order one or check the internet. The issue is price, a rebuild short block may be more then a complete used engine. Plus you would need a gasket set which adds to the cost.
Old Aug 25, 2008 | 11:55 PM
  #12
arrowdragon's Avatar
I see that there's an engine replacement thing, but I don't know if it's right. It says engine cradle which include the engine cradle, front suspension, and suspension components. Pricing for V6 is $840.
Old Aug 27, 2008 | 11:43 PM
  #13
The engine, trans, lower supension parts, axles, brakes, etc are mounted to the cradle. When the car is manufactured the cradle is installed into the frame from under the car, then bolted to the chassis.
Determine if the cradle includes the engine or just the cradle, suspension parts, etc.
Old Sep 15, 2008 | 11:14 AM
  #14
XxMerlinxX's Avatar
There's a 1MZFE longblock on ebay for $1075 plus whatever shipping is to you. It apparently has been compression checked and comes with a 6 month warranty. They've got 100% feedback on over 1500 transactions, so I would be confident I were bidding on it.
http://cgi.ebay.com/ebaymotors/94-99...mZ290260441555
Old Sep 19, 2008 | 02:43 PM
  #15
PyrMan3's Avatar
Listen im in nyc ill rebuild it for 450 plus parts, ? all thats wrong is, the crank bearings, cam bearings, rings , and possible cams, ill do it for you in a weekend,
woofohio
Jan 4, 2013 05:19 AM
cwaite2
Mar 13, 2012 01:46 PM
96camman
Jan 16, 2011 04:32 PM
ggcc
Apr 27, 2007 05:15 PM
