Toyota Camry 91 shaking when stopped
Old Nov 6, 2008 | 06:37 PM
Kasten's Avatar
Default Toyota Camry 91 shaking when stopped
I have a Toyota Camry 91 that shakes a lot when the car is in drive and is stopped but it is fine when its stop in neutral or park, or when the car is moving. The place I took it to get the oil changed and look at the problem says that one of the cylinders is missing firing due to a weak secondary ignition. Does this make sense? If it was missing firing would it happened only when its in drive and not moving? The place wanted $214 to fix the problem but I wanted to save some money and do some things myself. Got any ideas of what I should do next? I have some electronic background and a multimeter if it helps. Thanks.
Old Nov 7, 2008 | 12:14 AM
ALFORDThomas's Avatar
Default RE: Toyota Camry 91 shaking when stopped
You should take your car to a different repair facility for a second opinion. Have them try rotating the tires front to back. Sometimes the tires can make a slight pull even if the car is in alignment.
_____________
Racepages
Old Nov 7, 2008 | 11:52 AM
Kasten's Avatar
The shaking is the worst when the car is not moving at all so none of that should matter.
Old Nov 7, 2008 | 06:56 PM
What is the idle speed when in Park, Neutral, Drive.
Old Nov 7, 2008 | 07:11 PM
Kasten's Avatar
It seems about the same can't tell. I don't have a tachometer in my car to see the RPMs.
Old Nov 8, 2008 | 11:05 AM
Do not understand.
Is this a 4 cylinder or V6?
This engine should have only one coil for all cylinders.
4 cylinder primary coil resistance = 0.38-0.46 ohm. Secondary = 7.7k to 10.4K.
V6 primary = 0.41-0.50 ohms, secondary = same are 4 cylinder.
Plug wire reistance = 15K max.
For $214 you can buy the parts yourself and replace the coil, plugs, plug wires, cap and rotor.
Markamp
Jan 6, 2017 12:07 PM
CHARLESH
Jun 18, 2010 10:14 AM
blackCam99
Apr 23, 2008 10:30 AM
finarf
Jul 25, 2007 09:06 PM
steppinthrax
Jul 20, 2007 09:41 AM
