1994 2.2L Won't start
Old Nov 26, 2016 | 08:52 PM
mushisushi's Avatar
Default 1994 2.2L Won't start
My girlfriend has a 94 2.2L LE model Camry, and she needs it for work desperately but I can't figure out what the heck is wrong with it.
We went for a drive the other day, and 20 feet out of the driveway she put down the accelerator, the engine rev'd but the car felt like it was under a lot of load, and when she released the accelerator the engine died instead of returning to idle.
I have tried getting it to start, but all it does is crank. No misfires, no stumbling...NOTHING. I even tried starting fluid, NOTHING. No misfires, no stumbling. No cylinders fire whatsoever.
I already replaced the fuel pump (which was under warranty) so it cost me $0, and fuel is present at factory recommended pressures. All 4 plugs are receiving a spark (I removed them and cranked to see the spark). There are no vacuum leaks or anything that I can find.
I have no idea what else it could be. It bugs the heck out of me that not even starting fluid is helping when I have spark at all 4 plugs.
I (we) are both desperate to get her car to just last a little while longer before we can afford a new one for her to get to work!
Old Nov 26, 2016 | 10:14 PM
53burb's Avatar
next thing i would check is the timing belt....pull the distributor cap off and turn the engine over....if the rotor isn't turning, then your timing belt is probably broken....
Old Nov 26, 2016 | 10:21 PM
mushisushi's Avatar
Oh I did forget to mention I already checked the timing belt, I can see it with the cover off of it, and the rotor does turn when cranking.
Old Nov 27, 2016 | 01:40 AM
53burb's Avatar
was or is the distributor loose? it sounds like the timing is off.....
Old Nov 27, 2016 | 02:19 PM
The engine ran OK until it revved and died?
LoCoELF
Sep 29, 2016 10:10 AM
DWhittaker
Jun 21, 2014 04:53 PM
feanor70115
Feb 4, 2008 01:35 AM
feanor70115
Feb 1, 2008 06:46 AM
