1995 camry le: Heat comes out of air vents even if ac button is off
Old Jan 11, 2022 | 06:21 PM
eggochico's Avatar
Default 1995 camry le: Heat comes out of air vents even if ac button is off
Hello Everyone! I noticed recently that heat and a little cold comes out of the air vents even if the AC button switch is OFF. I also noticed my gas consumption go up, from 24mpg to 21mpg. Idling is around 700rpm while in Park, then goes down to 400-500 when in drive. It wasn't like this months ago. Please HELP! Thank you.
Old Jan 12, 2022 | 12:23 PM
V6 or 4 cylinder? Automatic or manual climate control system?
Old Jan 12, 2022 | 01:59 PM
eggochico's Avatar
Default 1995 Camry LE 4cylinder 2.2L
Manual climate control system
Old Jan 12, 2022 | 06:33 PM
Something called the Intake Air Control (IAC) valve sets the idle. The electric valve bypassed engine intake air around the throttle plate based on inputs for the engine computer. Try cleaning the valve. The internet has video's etc on this. If 4 cylinder the engine model is 5S-FE.
The manual climate system has a rotating **** the moves a valve in the coolant line going to the heater core. Have someone rotate the valve while you watch the valve arm for movement. The valve is located on a hose that goes into the firewall on the drivers side. A push pull cable moves the valve arm.
The climate system air intake chamber under the dash has something called a blend door. This door door mixes the air outputs from the heater core and AC evaporator. Make sure t the door is not stuck in the position that only allows hot air from the heater core.
The AC compressor is either on or off. The button turns the controls for the compressor on which the cycles the compressor on/off to maintain the chosen cabin temp. The button doesn't activate any blend doors, etc.
If decreased MPG check for vacuum hose and engine air intake hose leaks, spark plugs, etc.
Chao.0724
Jan 7, 2023 04:17 PM
NYGMEN
Jun 21, 2018 03:51 PM
Ervin Lenzy
Dec 15, 2016 05:52 PM
richpngu
Jun 1, 2010 07:11 PM
johnnee
Dec 8, 2005 10:57 AM
