Sponsored by:
Sponsored by:
98 camry erratic shifting ,speedometer and tach
Old 10-19-2010, 04:08 PM
carl455's Avatar
Default 98 camry erratic shifting ,speedometer and tach
I have 98 Camry that is having erratic shifting. the speedometer and tach also jumps around. I have replaced the transmission speed sensor and the instrument cluster. still having the problem, it is intermittent though you may drive 2 miles and it starts or you may drive 300 miles before it starts. any help would be appreciated thanks Carl
Old 10-19-2010, 09:49 PM
The tach is separate from the other circuits. Are you sure the tach is not jumping around because the engine RPM is jumping around?
Old 10-20-2010, 03:24 PM
carl455's Avatar
You are probably right on the tach, what would make the speedo jump around and the erratic shifting? the speed sensor has been change with a new one. The wires and all connections look fine. Is there something else that I should be looking for. thanks Carl
Old 10-20-2010, 10:13 PM
Might be a solenoid on the transmission. These are electric operated.
Might be shift solenoid E (also called SL,this controls the O/D operation. However there are 2 other solenoids.
You might determine if any transmission trouble codes are present.
Assume you checked the trans fluid level.
evidinhajr
08-11-2017 12:19 AM
pmotesrt
03-27-2016 05:43 PM
geven08
10-06-2014 09:31 PM
jr2sndbrd
01-07-2014 07:33 PM
jmhowe
10-24-2006 03:49 AM
Quick Reply: 98 camry erratic shifting ,speedometer and tach
