2000 Camry won't turn over
Old May 11, 2008 | 10:02 PM
The Shadow's Avatar
Default 2000 Camry won't turn over
I am very frustrated today!!! I have a 2000 camry, 4 cylinder with only 50,000 miles. Yesterday the engine was dead...wouldn't even
crank over. I bought a new battery......still would not crank over. Removed the starter and had it checked.......starter is functioning
normal. I don't think the problem is the alternator because I just put in a new battery. My next guess would be there is a short some-
where. Has anyone had a similar problem like this before? Thank you for your input on this one.
Old May 12, 2008 | 07:43 AM
pedro's Avatar
Default RE: 2000 Camry won't turn over
http://camrystuff.com/manuals/Gen4/Starting.pdf
Old May 12, 2008 | 09:45 AM
acidmeld's Avatar
Check the starter relay..
Old May 13, 2008 | 06:37 PM
The Shadow's Avatar
My 2000 camry still won't turn over. I have replaced the battery, pulled out the started and have it checked at auto zone. It works fine. I pulled the starter relay and had the
physics teacher at my school check all four terminals. It checked out fine. An obd II analyzer pulled up no code numbers. Does anyone have a hat trick they pull for my problem?
Thank you very much.
Old May 14, 2008 | 06:21 AM
pedro's Avatar
Does this car have a theft deterrent system? Are all your accessories working?
Old May 16, 2008 | 09:11 PM
icepik7878's Avatar
Does anything happen when you turn the key? Lights on dash, clicking noises, etc...
You had the starter out...did you attempt to turn the flywheel in the engine a bit?
If the engine froze up, you won't be able to move the flywheel.
If you don't have any lights on dash or clicking noises....
Is it the original key? Theft system looks for the electronic key.
Do you get headlights to work, and no dash lights? Then it's something electrical to the starter.
Could be a lot of things, do a little testing of different things, and see what does and doesn't work.
dmshep
Dec 27, 2014 05:48 PM
FireTiger7
Jun 8, 2014 05:19 PM
mooreck3
Nov 16, 2010 11:34 AM
newbiescamry
Nov 28, 2008 05:55 AM
