2001 camry LE won't start
for i can't start my 2001 toyota camry LE when i try to jump it it won't crank and i lose power to the car. i've tried disconnecting the battery and when i reconnect it i get the power back but still no crank or start, only one click from the starter area. it's recognizing my key and fob because they both work. i also tried resetting the anti-theft system but that didn't work either. the battery is brand new and has a full charge. i also remove the starter and it also tested perfect. how can i get my car started?
Search instead for i can't start my 2001 toyota camry LE when i try to jump it it won't crank and i lose power to the car. iv'e tried disconnecting the battery and when i reconnect it i get the power back but still no crank or start, only one click from the starter area. it's recognizing my key and fob because they both work. i also tried resetting the anti-theft system but that didn't work either. the battery is brand new and has a full charge. i also remove the starter and it also tested perfect. how can i get my car started?
Search Results
Videos
Does the car have an aftermarket theft system?
The Toyota system will allow the engine to crank over but not start.
Try testing the starter on the engine. Jump the starter relay terminal on the solenoid with +12v. This is the small terminal on the solenoid with small wire going to it.
