2002 Camry problem
Hello everybody, Newbie here. 6 months ago I bought a 2002 Camry in PERFECT condition, V6 with only 130,000 miles. It has run GREAT, but suddenly a couple day ago the blower motor quit working- No A/C or heater. I'd like to attempt to repair it myself, before putting in a shop, but I have no idea where to start! I've looked in fuse box and can't find a fuse that specifically says blower motor. Does anybody have any ideas? I would appreciate any advice. Thanks a lot!
Hi: I FINALLY had time to check those fuses, I found and checked the one inside the car, but I cant seem to pull the 50A, it's a square fuse (or breaker) with a clear cap, I'm afraid to tug on it too much, afraid I'll break it. How would I check it? Thanks a lot!
The 50A is bolted into the box. Don't pull it out from the front.
You should be able to view the filament inside.
Or remove the HTR relay and with on, check for power at the No 5 socket pin.
Pin 1 is 12v from 10A fuse.
2 goes to AC control assy.
3 blower motor control.
4 is ground wire.
4 is ground wire.
