2004 Camry V6 Throttle and Transmission Problems
Old Oct 22, 2017 | 07:29 PM
pandagains's Avatar
Default 2004 Camry V6 Throttle and Transmission Problems
So I have a 2004 Camry 3.3l V6 3mzfe with ~100k miles bought brand new 13 years ago. The problem is when taking off from slow speeds, the throttle takes some time before the car actually responds. Most of the time I have to give it a bit more gas, causing the car to launch forward and kind of bogs a bit. Other than the throttle, the transmission also shifts super hard. At randoms times, the car shifts super hard causing the car to lurk forward. This is especially dangerous because it happens in parking lots. Oil is frequently changed, throttle body recently cleaned, fresh tires and alignment, timing belt and spark plugs changed in the past 5k miles, Mass airflow sensor cleaned recently, etc. I cannot find out why this is happening other than possibly the manufacturers fault. If there are any solutions, please let me know. Thanks.
Old Oct 23, 2017 | 01:23 PM
Was the trans fluid ever changed?
Have you checked the trans fluid level?
Old Oct 23, 2017 | 10:02 PM
pandagains's Avatar
I don't remember exactly when the transmission fluid was changed, but upon inspection it is bright pink and levels are where it should be.
Old Oct 24, 2017 | 11:40 AM
Check throttle and shift cable adjustment.
Beyond this it could be internal. A bad solenoid valve or valve body issue.
wyokobi
Mar 27, 2014 10:24 AM
cad1292
Jan 7, 2012 11:44 AM
OntarioCamry
Jun 22, 2009 12:34 AM
zabije cie
Apr 19, 2008 12:38 PM
camryproblems
Oct 29, 2007 07:15 PM
