3rd gear troubles
Old Nov 25, 2006 | 11:50 PM
greenfire's Avatar
Default 3rd gear troubles
I have a 1987 with a 5pd manual transmission. I can shift from 2nd to 3rd normally, but can not shift from 4th to 3rd unless the car is well under 20mph. Is this normal or what can the problem be. It shifts fine and the clutch feels great otherwise.
Old Nov 26, 2006 | 10:53 PM
lavalleemike's Avatar
Default RE: 3rd gear troubles
I had a similar problem with an 89 a while back the dealer told me it had some thing to do with syncros. and its was exspensive to fix. It last over 290k so i dont think you should be worried
Old Nov 26, 2006 | 11:01 PM
greenfire's Avatar
Yea this seems like something Ill just have to deal with. I read about a clutch master cylinder?? Is this the small resevoir behind the brake master cylinder resevoir. I guess I need to put some fluid in there...
Old Nov 28, 2006 | 08:00 PM
that may help your issue a little bit
Old Dec 16, 2007 | 09:19 PM
guate6's Avatar
I have the same problem with my 2001 4 cyl camry. The best way to down shift, is to put it in second (without releasing the clutch...just hit the clutch, do 2, then immediately go to 3), then upshifting allows smooth shifting with no noise.
h.cardle4
Oct 21, 2013 10:56 PM
h.cardle4
Oct 21, 2013 10:37 PM
h.cardle4
Oct 19, 2013 08:51 PM
Velas
Jul 19, 2010 03:55 PM
a1986camrydlx
Jan 25, 2006 09:06 PM
