3sfe camry
3sfe camry
Hi guys
New to the forum from S.A
Hope someone can assist
Did a engine swap and stuck at distributor
Would like to know If someone knows where the wires needs to be connected of the 2 connectors on the distributor on the 3sfe engine
It has a 2 pin on the one side and 4 pin on the other for example which wire is for + which is ground and signal
Will use aftermarket ecu and need to figure out where to connect the specific wires
Thanks in advance
Thanks in advance
Is the ign coil built into the distributor?For ign coil
Black/orange is B+ to ign coil
White/blue is neg for coil
Sensor pickup
The distributor has two pickup sensors
G1 and G- are connected to one sensor coil. This is camshaft position sensor.
NE is connected to the other. This is the crankshaft position sensor.
Red is sensor coil G1
Black is G-
White is NE
Brown is ground for wire shielding for sensor wiring
Sensor pickup
Black is G-
White is NE
billbruce
10-14-2011 09:37 PM
SymtecX
02-27-2006 03:16 AM
