85 camry LE AC Pulley issue
Old Nov 20, 2008 | 07:26 AM
ephebert's Avatar
Default 85 camry LE AC Pulley issue
Need some help here. First time working on a Toyota and this one has been abused a lot but I am trying to help a friend keep her car running.
She asked me about the belts sqeeking and that's when I noticed that they only had a belt running from the crank pulley to the Alt Pulley. It has A/C and that pulley is cutting into the belt. The problem I see is that the A/C compressor pulley is not aligned with the crank or the Alt pulleys. Is there that much play in how the compressor can be installed or something else that I'm not seeing. I haven't botten under the car or see much more than what you see here. Looking for some help before I try and tear into it.
[IMG]local://upfiles/6828/66F354001C16405AB1406D51B071C9D9.jpg[/IMG]
Old Nov 20, 2008 | 08:40 AM
pedro's Avatar
Default RE: 85 camry LE AC Pulley issue
Is the A/C on a car that old even working? Usually the compressor mounting is non-adjustable and thereshouldn't bemuch slack on the pulley either. The only way to adjust the pulley is with a shim(s) on the pulley shaft to adjust the correct clearance of the clutch. You can try tightening the pulley or even adding/removing the shims. If she doesn't want A/C then why not just remove the compressor pulley or even the compressor?
Old Nov 20, 2008 | 06:56 PM
kartl's Avatar
I totally agree the brackets are fix, now if you want to realign it you have to provide a new bracket for the compressor you can ask a machine shop to make you one.
_____________________________
fuel saving devices
jimbak3
Oct 28, 2022 02:20 PM
Tarek
Aug 9, 2009 06:52 PM
jfcjr01
Aug 5, 2009 06:36 AM
1992I4
Dec 26, 2008 07:40 PM
Camry05WS
Sep 21, 2008 09:12 AM
