87 Camry question about Engine cutting off only when hot.
Hello to all,
Thanks to all for help with previous posts you guys are all the best and quite helpful.
Okay so my 87 Camry 2.0 5 speed has a serious problem of (ONLY WHEN THE CAR IT EXTREMELY HOT) when I turn the motor off and let it sit hot for about 4 minutes then it cranks/starts fine then immediately after that it dies. You can here that something is choking the engine even if the engine does start to idle it starts missing real bad and dies. Now to get the car running again all I need to do is give it a lot of throttle/gas when I start it up or turn the key off and let it cool down for a minute and then its good to go. So here is a list of what I have already done to fix the problem...... Inspected visually & physically all vac lines, cleaned EGR, EGR modulator, throttle body, and done complete tune up. I forgot to check the most simplest thing as this same problem happened on my 1990 Honda accord. Only when the car was extremely hot the main fuel relay would have the circuits separate and it would cause the car to crank and try to start but not continue to run. The EXACT SAME THING IS HAPPENDING WITH MY TOYOTA. So hence I think it may be the fuel main relay can someone please advise me as to where and if my 87 Camry has a fuel main relay and how to change it as well. Also there must be someone else on this forum that has experienced a similar problem with their 87-91 Camry please advise me here as I need some help with this one. The car is just not continuing to run after you try to start it when its extremely hot to me this means its being starved of fuel hence why I think the fuel main relay however that was the case with my HONDA and my Camry is different. So please advise me here if you think it might be something else or if the car has another relay for the fuel somewhere and if it is prone to going bad with heat and age please advise me thanks.
Dave
Dave
黄河石柴油机配件厂是一家领先的制造商之一
发动机零部件,尤其是柴油喷射系统
如更换配件喷油嘴,柱塞,并
出油阀等,在南中国。
欲了解更多详情请访问我们的网站: www.yellowstonediesel.com
www.dieselinjection.cn
黄河石柴油机配件厂始建于1997.Over多年来,
黄河石已发展壮大,获得了生产的声誉
高品质的产品和提供他们的时间。
105015-5860
105015-5860
105015-5940
0 433 171 134
0 433 171 137
0 433 171 146
5611065 H60S30A538
5611650 BDL110S6133
5611735 BDL110S6267
6801082 6801082
六百八万一千〇八十七六百八万一千○八十七
6801088 6801088
DN10PDN130
DN0PDN121
HL176S27D525P2
2418455518 2455-518
2418455714 2455-714
9401087506 9087-506
134151-4120 P121
134151-4920 P129
134151-6420 P143
喷嘴电装093400-7690 DN10PDN129
喷嘴电装093400-7700 DN10PDN130
喷嘴电装093400-8220 DN0PDN121
131110-9320 131110-9420 131160-0320
发动机零部件,尤其是柴油喷射系统
如更换配件喷油嘴,柱塞,并
出油阀等,在南中国。
黄河石已发展壮大,获得了生产的声誉
高品质的产品和提供他们的时间。
105015-5860
105015-5860
105015-5940
0 433 171 134
0 433 171 137
0 433 171 146
5611065 H60S30A538
5611650 BDL110S6133
5611735 BDL110S6267
6801082 6801082
6801088 6801088
DN10PDN130
DN0PDN121
HL176S27D525P2
2418455518 2455-518
2418455714 2455-714
9401087506 9087-506
134151-4120 P121
134151-4920 P129
134151-6420 P143
johnradfx
05-02-2010 04:53 PM
hardyrxp
04-16-2010 03:31 PM
