Old Aug 26, 2015, 01:57 PM
How-Tos on this Topic
Browse all: Lighting Guides
Print Wikipost
93 toyota camry no reverse lights.
Old Feb 29, 2012 | 09:30 PM
ac2011's Avatar
Default 93 toyota camry no reverse lights.
i changed the bulbs and the still dont work. anyone have this issue?
Old Mar 1, 2012 | 12:51 AM
ac2011's Avatar
ok so i did some research online turns out other people had this issue turns out to be the harness broke right near the trunk hinge. mine was 2 wires a red wire and a white wire with a black stripe. i reconnected them i added 3 inches of new wire to have some play opening and closeing the trunk. i will upload pics later
Old Mar 8, 2012 | 06:29 PM
Guyii's Avatar
Hey I have a 1988 V6 Camry and I have the same problem except My brakes don't work when I press the brake pedal and the reverse lights do not come on. Can this solution work?
Old Mar 8, 2012 | 09:25 PM
Check for damaged wiring in the area of the post. If damaged the solution should work.
camry96ss
Nov 30, 2011 06:51 PM
artnsf
May 24, 2011 01:01 PM
naltal
Jul 22, 2009 07:31 PM
tjsilva
Nov 3, 2008 12:39 PM
Arthur84
Nov 11, 2006 06:05 PM
