94 camry running rough PLEASE HELP
Old Mar 18, 2013 | 05:59 PM
  #11
Resistance between + and - terminals of coil should be as follows:
0.36-0.55 ohm cold (14F to 122F)
0.45-0.65 ohm hot (122F to 212F)
Also check resistance between the + terminal of coil and coil socket where the large ign wire to the distributor plugs in.
9.0-15.4 K ohms cold
11.4-18.1 k ohms hot
Check resistance of signal coils inside the distributor.
With distributor cap facing you and electrical plug oriented down, from left to right the connections are G(-), G2, G1, NE.
G1 and G(-) 125-200 ohm cold, 160-235 ohm hot
G2 and G(-) same as above cold, same as above hot
NE and G(-) 155-2500 ohm, 190 - 290 ohm hot
kramer1397
Dec 4, 2013 01:34 PM
TREADDOG69
Aug 9, 2011 02:50 PM
shloho
Jun 12, 2010 03:51 PM
jackkpts
Jul 18, 2009 07:23 AM
62 chevy
Jul 19, 2007 04:22 PM
