94 toyota camry no spark help needed.
Old Oct 7, 2015 | 11:38 AM
jkk101's Avatar
Default 94 toyota camry no spark help needed.
My 94 Toyota camry wont start .At first the car would be hard to start I would drive it to a store and when I returned and tried to start it it would crank and crank before it would start .Done this for about 3 weeks sometimes it would fire right up and others you had to crank it for a couple min before it would start .
Then one day I was driving it and it died I pulled over and it started right up but after parking it at home it just wouldn't start so I pulled a plug out and had my ole lady crank it over while I checked for fire nothing .Jumped te1 to e1 and got code 12 tried to start it and it fired right up drove it around after and was fine for a few more days but after parking again no start and no firing so I order a distributor put that in but the same result no spark .
Do you guys have any ideal where I should go from here?
Old Oct 7, 2015 | 12:41 PM
jkk101's Avatar
Ok just to update anyone I also took a meter and checked the red/white wire from the igniter and also the red and white wire on the small plug to the distributor with the ignition on both had a 12 volt reading.
Old Oct 7, 2015 | 03:58 PM
Code 12 is a signal problem between the distributors signal coils and the ECM. Check the wiring and connectors between the distributor and ECM.
Old Oct 10, 2015 | 04:59 AM
jkk101's Avatar
OK today I will check the G+ and G- and NE+ and NE- at the distributor and post results .
Old Oct 11, 2015 | 04:50 PM
jkk101's Avatar
OK so I checked G+ G- and NE+ and NE- both had good readings however when I checked my primary coil résistance I got nothing I tried while cranking and also with just ignition on but failed to get any readings from it.This is a new distributor whats the odds the coil is bad in it?I looked at my old coil and it had a massive 16th inch crack across the top .
Old Oct 11, 2015 | 05:43 PM
jkk101's Avatar
Ok so I believe I had my meter on to high a ohm setting I set it to 200 ohms and got a reading of 01.6 off the primary coil résistance.According to the manual should be
Primary coil resistance (Cold):
0.38–0.550
Primary coil resistance (Hot):
0.45–0.650
I`m assuming that is an ok reading .If so then all my checks for the distributor including air gap is ok.
Old May 12, 2020 | 02:11 AM
martinoermando's Avatar
Showbox jiofi.local.html tplinklogin but after parking it at home it just wouldn't start so I pulled a plug out and had my ole lady crank it over while I checked for fire nothing .Jumped te1 to e1 and got code 12 tried to start it and it fired right up drove it around after and was fine for a few more days but after parking again no start and no firing so I order a distributor put that in but the same result no spark .
traviskx
Aug 21, 2019 08:45 PM
Pauly.Lyus
Jan 16, 2017 02:25 PM
tricks4you
Oct 24, 2011 11:17 PM
marswus
Mar 17, 2008 12:48 PM
gmayor
Mar 6, 2005 04:08 AM
