95 Camry Battery-Security Activation Problem
Old Aug 22, 2011 | 06:30 AM
Rosettiski's Avatar
Question 95 Camry Battery-Security Activation Problem
First-time Camry owner (!) had to unhook the battery for some minor front-end work (new radiator and front engine mount), and now it appears the security system has disabled the engine. I've tried using the door key to no avail so far; I also looked for the "alarm fuse" to no avail. A friend suggested it might have once had an after-market system in it. What is the cheapest way to figure out what to do? My baby won't start!
Old Aug 22, 2011 | 11:22 AM
Would not start as in turns over but does not start?
Do not think this year of Camry did not have a factory or dealer installed immobilizer system. If it did check for a blinking red light on the dash panel.
If aftermarket check for reset button or switch under the dash.
Old Aug 23, 2011 | 05:57 AM
Rosettiski's Avatar
Suspected all alon it was after-market, but there was nothing under the dash. Ended up having to use a pro to disable/remove the prior owner's system.... Thanks, though.
the desolate one
Sep 7, 2019 03:36 PM
hplar
Aug 15, 2013 06:13 AM
snation
Aug 22, 2010 11:57 AM
2007xle
Aug 7, 2009 09:50 PM
