96 Camry replace Fuel Filler pipe
Old Oct 15, 2012 | 09:41 AM
welshes99's Avatar
Default 96 Camry replace Fuel Filler pipe
Any advice on replacing a fuel filler pipe on a 96 camry. Have the pipe purchased and wanting to get some advice before getting started. Never done this one before. Tank is less then half full.
Old Oct 15, 2012 | 10:45 AM
The Autozone website may have info in its vehicle repair guide section. Or pickup a Haynes manual for $20.
Access to the fuel pump area is under the lower seat cushion behind an oval sheet metal plate on the chassis.
The EVAP system may be in the tank area and require removal. There would also be an EVAP hose connection on top of the tank can be accessed once the tank is lowered a bit.
The fuel pipe is held to the chassis by nuts in the fuel cap area. The tank held in place by two straps.
Suggest you place something under the tank to support it when unbolting the straps and allow for slowly lowering the tank to disconnect anything that still remains attached such as any EVAP hoses on top of the tank.
Old Oct 16, 2012 | 09:53 AM
welshes99's Avatar
Great, I'm planning on giving it a go this weekend. Appreciate your help.
therealjab
Jul 11, 2011 10:59 AM
gotrojans82
Nov 15, 2009 12:36 PM
drickelton
Jul 11, 2008 10:13 PM
cisco2992
Jul 8, 2008 12:40 PM
Demiandvm
Aug 26, 2007 03:49 PM
