96 Camry Will Not Spark
Old Jun 30, 2008 | 05:43 PM
elittleton73's Avatar
Default 96 Camry Will Not Spark
I've got a 96 Camry that will not spark. If I Cross Out the EFI Relay it will crank. Currently I've changed the PCM, Circuit Opening Relay and the Engine Compartment Distribution Center. Basically I've run out of options. If anyone has any ideas I would greatly appreciate it. Thanks in advance.
Old Jul 1, 2008 | 02:36 PM
Default RE: 96 Camry Will Not Spark
The engine will not crank with the EFI relay crossed, can you clarify this more?
Have you checked to make sure the timing belt is not broken, determine if the rotor turns as you crank the engine.
Old Jul 2, 2008 | 10:34 PM
khooper's Avatar
Have you made sure the distributor is actually turning? Did the distributor include a new coil?
______________________________
Check out: Autopartswarehouse.com
Old Jul 7, 2008 | 09:56 PM
njensen's Avatar
check the timing belt, or have it checked.
manty1
Apr 10, 2013 04:54 AM
cjsmith0703
Apr 25, 2012 10:24 PM
organica
Jul 17, 2011 09:15 AM
brian37r
Aug 30, 2010 06:07 AM
nimainewman
Mar 22, 2007 11:49 PM
