97 ABS Light
Old Aug 30, 2006 | 04:42 PM
leadhand's Avatar
Default 97 ABS Light
Hi everyone, this problem likely has more than one answer but here it is.
My sons 97 Camry has the ABS light on, it just started yesterday, does anyone know what the problem(s) is and does it pose any danger to ignor it for a while.
Thanks
Lead
Old Aug 30, 2006 | 05:02 PM
lavalleemike's Avatar
Default RE: 97 ABS Light
I would have it checked out... It could be any number of things from the computer to one of the sensors.
Old Aug 30, 2006 | 08:56 PM
jasmtz531's Avatar
Get it looked at because when the ABS light is on, the PCM will not activate ABS if your wheels lock up under braking.
Old Aug 31, 2006 | 12:12 AM
nodrogkam's Avatar
yeah it means you have no abs. have you done any suspension/brake work recently?
typically replacing the struts without removing the speed sensor will cause the abs light to go off.
grocerygettercamry
May 26, 2009 12:33 PM
gwar28
Nov 5, 2008 11:26 PM
granadaCoder
Jul 29, 2008 12:43 PM
Slomo_01
Jan 22, 2008 09:47 AM
92CAMRY
Jul 14, 2006 05:52 PM
