ac works when it pleases (apparently)
Old Apr 21, 2016 | 12:18 PM
  #11
Totoro Camry's Avatar
Bumping thread from almost a year ago, today the ac compressor finally failed again, couldn't find a relay for it but just a 10amp fuse, removed fuse to check it, wasn't blown but when I put it back in the compressor started spinning again, I'm hoping just corrosion on the terminal is the culprit
Old Apr 21, 2016 | 10:09 PM
  #12
The magnetic clutch relay is in a relay box, engine compartment drivers side.
The A/C system has various components such as max/min pressure sensors, amplifier, speed sensor, etc. Its possible the system reset and the problem will occur again.
Have you checked high/low pressures when A/C is operating with a gauge set?
Old Apr 22, 2016 | 04:26 AM
  #13
No because I didn't have my gauges with me yesterday when it happened, but it's blowing cold again just fine with a newer fuse, less corrosion on the prongs
hayhayday
May 12, 2009 10:10 AM
offchops
Feb 19, 2009 11:44 AM
Tralfamadore
May 2, 2008 03:49 PM
Toysrme
Feb 19, 2006 12:09 AM
