battery drain
Old Dec 30, 2007 | 06:24 PM
walt7474's Avatar
Default battery drain
Hi
I have a 96 Toyota Camry with a strange problem. It seems that there is something draining my battery when I drove it. it only happens when the weather is cold. I have replaced the alternator three times now due to voltage regulator failure. Any suggestions?
Jerry
Old Dec 31, 2007 | 01:51 AM
danomatic93's Avatar
Default RE: battery drain
Go to your local Autozone, Advanced Auto Parts, NAPA, etc, and have them check the battery and alternator.
Are you buying rebuilt alternators?
Old Dec 31, 2007 | 06:24 PM
walt7474's Avatar
Had the alternator tested last week. It checked out OK. Only seems to be draining the battery when it's running. Could there be a short somewhere?
How do i find it?
Old Jan 1, 2008 | 07:37 AM
pedro's Avatar
If the battery is ok and the alt is putting out proper charge voltage/amps then I would trace the wire/connections from the alt to the battery that charges the battery.
Old Jan 25, 2008 | 01:56 PM
walt7474's Avatar
OK. So here's an update. Alternator finally died today. I went last week and bought a tester that plugs into the cig lighter. It was OK for a week then on my way home from work yesterday the alternator died. I got it home and put it on the battery charger overnight. Went out htis morning to start it before I left for work and alt was charging fine. It ran for ~15 minutes then stopped charging. Went to NAPA and they said they'd replace it one more time. What can be causing all of these alternator failures?
Old Jan 25, 2008 | 02:30 PM
pedro's Avatar
Rebuilt alts and starters have to have the worst QC of all the parts I hear about. You may want to buy new for the hassle. The last Bosch I bought worked fine for many years butI don't know how their quality is now.
Old Jan 25, 2008 | 02:53 PM
walt7474's Avatar
Yeah. I could believe I got one bad one. But, I'm going on the fourth. They only seem to fail when it's cold out.
Petes
Sep 2, 2009 01:39 PM
OliviaMorgan
Apr 9, 2009 09:11 AM
camown
Jan 6, 2009 10:07 PM
Lobstrerbreakfast
Sep 8, 2008 09:26 AM
chad
Jan 16, 2008 12:22 AM
