Brake indicator always on
Old May 14, 2008 | 02:55 PM
usnavyvetmissouri's Avatar
Default Brake indicator always on
1998 Camry, 4cyl, not mine. The dash indicator for the brake is always on. Am I just looking for a bad switch on the parking brake (which is off) or is this indicator lit by low fluid or other brake problems? Any source for a wiring diagram? Thanks in advance for any help.
Old May 14, 2008 | 04:40 PM
Default RE: Brake indicator always on
The light is for both parking brake and low brake fluid. Might be a Red/White wire(s).
You should be able to move the low brake fluid switch by hand.
Old May 14, 2008 | 05:10 PM
If it turns out to be the park brake switch, what will suffice as a moulding remover to disengage the clips on the moulding panels? In any event, thanks for the info.
Old May 16, 2008 | 06:45 AM
results: problem with indicator was low fluid, no leaks though, just needed front pads really bad. All fixed, thanks again.
jaycamry26
May 31, 2009 07:54 PM
Karl99
Nov 25, 2008 06:07 PM
99camry
Jan 2, 2007 08:50 PM
