Browse all: Engine Problems by Sympton
- Toyota Camry 4th gen Why is Car Getting Bad MPG
Guide to diagnose trouble and recommended repairs
Camry - Hesitation/Stuttering/bad MPG
(Thanks Toyomo for the reply to my post over the weekend!)
1993 Camry LE, 260K Miles
I still have the same problem of hesitation & stuttering with Not-so-good MPG (15-16MPG) when trying to punch the gas peddle for acceleration. It seems to run better and smoothen out at around 3500RPM. The symptoms are worsened when the A/C is turned on...
Toyomo helped alot over the weekend! On his advice, I replaced the coolant temperature sensor first which made the biggest difference in improved performance.
-Next, I replaced the Ignition Coil with minimal improvement (luckily only $40 and 2 hours of my labor)
-Next, I replaced the Throttle Position Sensor with some improvement (used one pulled from another Camry at a junkyard, seemed in very good shape compared to my OEM TPS. ...
Still, the same symptoms are lingering...
Toyomo also recommended checking the fuel pressure to see if a new pump would be in order..
Any other recommendations?
(this problem is very frustrating at this point!!!!)
I read your prior thread to this one as well. Sounds like your on the right track. Have you considered checking your cat converter? a plugged one can cause loss of power. Also just a thought a leaking manifold will cause and unmetered air leak and cause your o2 sensor to see lean which will richen your fuel mixture hence the flooding?
2000, 2010, 91, ac, acceleration, air, camry, car, conditioning, gas, hesitation, studder, stuttering, stutters, toyota
