Dash Dimmer Warning!!
Old Feb 2, 2007 | 02:46 PM
pedro's Avatar
Default Dash Dimmer Warning!!
My dash light dimmer has not been working and the dash lights, while theydid light,did not adjust brightness. No big deal except for a while I havebeen smelling a slight burning plastic smell.Hardly noticable and seemed to come and go. Today Itraced the smell to the dash dimmer switch. When I removed the switch the outer casing was partly melted and black. Could have been afiredanger if the fuse did not blow. If you have similar symptoms I would suggest immediate replacement of the dimmer switch.My model year has a small access cover below the switch so removal of the dashwas not necessary.
Old Feb 2, 2007 | 03:10 PM
nodrogkam's Avatar
Default RE: Dash Dimmer Warning!!
what the heck..thats the frist ive ever heard of such a thing. i wonder wat caused the overload.
Old Feb 2, 2007 | 04:28 PM
pedro's Avatar
Reostats do produce heat as they create resistance to reduce voltage. This may have been just an isolated thing on one part. I replaced it with a wrecker part off another Camry. Prior to installing I did test the replacement using the procedure from the on-line repair manual. You simply cannot use an OHM meter to test.
mjam714
May 31, 2012 08:57 PM
Suny
May 20, 2012 12:16 AM
beentherebefore
May 26, 2011 09:26 AM
trdcamrygracia
Dec 16, 2005 02:26 PM
CKSAMartin
Dec 16, 2005 02:24 PM
