Warning Light?
Old Dec 12, 2005 | 11:48 AM
CKSAMartin's Avatar
Default Warning Light?
I'm driving a 91 Camry 4cy with a newly rebuilt engine. The oil light keeps coming on when I press on the brakes, however, a check of oil and brake fluid levels indicates I'm not running low on either. Any ideas what else this could mean? (the engine has less only a hundred or so miles on it since the rebuild)
While anyone's at it, I'd love to know what all the warning light combinations mean.
I learned a year ago that BRAKE + BATTERY = alternator not working.
Old Dec 12, 2005 | 04:14 PM
Patrick's Avatar
Administrator
Default RE: Warning Light?
it could be a problem with the oil sending unit...
Old Dec 12, 2005 | 05:14 PM
CKSAMartin's Avatar
It is supposed to have a new one, but I guess that's an easy place to start... Is it possible to switch wires on the brake, battery or oil lights?
I can recall when I had battery problems and pressig on the brake pedal caused the warning lights to go off. I just can't understand how pressing on the brake pedal has anything to do with the oil... I tried coasting to lower RPM and no light went off. It only happens at low RPM When the brake pedal is depressed.
Weird.
Old Dec 16, 2005 | 02:24 PM
Patrick's Avatar
Administrator
it really is weird...did you say that youve had wiring issues in the past?
weez
Sep 29, 2018 01:30 PM
LeeM
Oct 2, 2011 10:54 PM
Octapulse
Nov 5, 2008 11:31 PM
Camrydriver
Oct 1, 2008 08:47 PM
green giant
Feb 19, 2006 04:29 AM
